421 - 436 of 436 Posts
2005 buick rainier
PCB Pad Lift - Possible fix
Folks,
Just a possible fix if you’ve been unlucky enough to lift (and destroy) a pad when changing the motors. First things first….don’t use too hot an iron. I’ve changed these motors in the past using a 30W with no issues. My new adjustable temperature iron I think is what caused my problem in that I was probably closer to 50W than 30.
So I managed to lift and destroy two pads. What you will see very close to the motor leg is a small solder ‘dot’. If the motor leg was soldered correctly (ie: pad intact) you will measure zero ohms between the motor leg and this solder ‘dot’. To make sure we are ‘apples to apples’ take a ohmmeter and measure from a good motor leg to this solder ‘dot or blob’ and you should see zero ohms.
What I was able to do is bend the motor leg over and touch the solder ‘dot’. Then very gently with a small blob of solder on the iron tip touch the motor leg and solder ‘dot’. Use your finger nail to keep the motor leg touching the solder ‘dot’ whilst you apply the solder drop from the iron. Be quick, the objective is to get a connection without disturbing the solder ‘dot’. I then applied a tiny amount of silicone sealant just before the leg to dot connection in the hope that it will not come loose and break connection. All good thus far. One other point….the pads I damaged were on a motor that was working so you may want to go for the ‘if it ain’t broke leave it alone’. That had been my approach over the years and I was down to the last two motors, one was bad and I thought I’ll do both rather than keep monkeying around with the cluster. I wished I’d just replaced the busted one as the one I messed up was working fine, but hopefully that will be it and I won’t need to go in there again.
If you are contemplating this job:
• I would say a 30 to 40 W iron max with a pointed tip.
• A vacuum solder sucker, this will give you speed to get the old solder out of the way quickly....but it is a vacuum device, if you have the pad too hot it may well pull the pad off.
• A dash brush and some isopropyl to clean the area prior to new motor installation.
Good luck!
Instrument panel
this is gonna sound kinda dumb but, can you buy a new instrument cluster already put together and just pop it in and connect the wiring harness and thats it? this will be my first time trying to solder anything and im alittle worried ill really screw things up. and if you can buy one already to plug and play can someone post a link on where to get one?
thanks
Yes, Dorman sells a replacement instrument panel. You can pick up the new one at Autozone and when you return the bad panel, they will rebate part of the price, net is approximately $300.
2005 buick rainier
Interesting stuff indeed! I was thinking I might have to get a $900 GM fix after I nearly screwed up two motor replacements last week. What I'm also reading is they come with the VIN and mileage set and you are ready to go. Finally an alternative to GM. Thanks for the info
https://www.summitracing.com/parts/rnb-599-325/overview/year/2005/make/buick/model/rainier
Stepper motors
Are you saying that just changing the stepper motors is harder than it seems? I was thinking of going in that direction, but now I have second thoughts. PS: If you order the subject Dorman product from Autozone, you can pick it up at one of their stores and return the core to the same store. Eliminates some of the shipping hassle.
Ignore my last question. I just read your post about self replacing the stepper motors and realize that is beyond what I would want to attempt!
2005 buick rainier
Well...you could have a pop at it before springing for a new cluster. The motors are a few bucks on Amazon. If you do order...get a supplier that ships from the States. My second batch came from China and took weeks, though they do seem ok so far quality wise. I guess one thought would be getting the core rebated if it is visually badly damaged by aborted repair attempts. It is tricky if you haven't done much in the way of soldering. I think the main area folks will screw up is using too hot an iron (30 W should be sufficient) and possibly trying to 'clean the hole of all old solder'. The latter will risk pad lift. What I do is as soon as I can see some solder melt get the vacuum sucker over the joint and suck up what solder I can. Then see if I can break any remaining connection by gently jiggling the motor leg with a pair of needle nose pliers. Remember the motor leg is a thin piece of wire, it doesn't need the entire hole to be clear of solder to pass through. The enemy I believe is heat on the board pads, if they lift you have a problem, but all may not be lost as you can see in my post from a week ago. That was self inflicted by using an iron that was too hot.
2009 chevy trailblazer_lt
Hi
I've read that Trailblazers from 2002 to 2005 use x27 168 stepper motors. What stepper motor is used for 2006-2009?
Thanks
2006 gmc envoy_denali
I am going to do my swap soon. My speedo randomly goes up when I shift to drive to 10mph and then I need to turn off and on my truck to 0 it.
This guy looks great, I just want to verify which to order.
X-25-168 is what guide says but I see x27 168 most stores eBay or amazon. which should I get. I have a 06 gm envoy Denali.
Thanks!
Purchased 6 stepper motors on e-bay and installed them several weeks ago with no issues. Now I notice that one of the dash lights is not working. I would like to replace all 8 with leds. Does anyone know what voltage led is required?
Hey guys, just letting you know that i have succesfully performed stepper motor transplant. I replaced my speedometer motor & it was really easy. No more guessing on how fast i'm going.:woot:
What kind of solder do you use?
Stepper motors verse cluster
My question is what is the problem if I install a used cluster from another vehicle in stead of replacing stepper motors. Would there be a problem with the pcm readings. Not worried about mileage because mine is over 200,000 and not recorded.
2003 gmc envoy_slt_xl
Solder I used
What kind of solder should I use and soldering iron?
When I replaced my stepper motors in the instrument cluster I used a 25 watt soldering pen and electronic grade rosin core solder. Caution, avoid over heating the soldering pads on the circuit board. I used desoldering braid to desolder pads for a clean soldering connection . If you do over heat a circuit board pad you can always use a jumper wire. I did this on one of my steppers. This process eliminates having to buy a new instrument panel then having a dealer to reprogram your computer.
2004 gmc envoy_slt_xuv
Thanks for all the assistance provided by this post and the several YT videos available out there. I was able to get this done right by myself the first time after some soldering/desoldering practice on scrap electronics. Here's one small tip, if not already posted before. On my first test drive everything worked great except for the speedometer (which is the second most important one to my wife). I thought that perhaps I had goofed up the desoldering/soldering, but the tip on checking the resistance on the adjoining solder dot ruled that out - turns out I did a great job. I had heard some clicking in the cluster while driving, so I thought that perhaps the speedo stepper was just bound up. So after I calibrated the needles to the correct position but before I hooked the cluster back up to the vehicle, I moved all the gauges to their far right (well, as far as possible without interfering with the bezel). Then when I plugged it back in, they all moved left and back to their reset location. That did the trick - now all gauges are working as they should and displaying the correct readings!
Hi guys!
I am actually a Tahoe owner chiming in here.
I also did a write-up on replacing a stepper motor here:
Stepper Motor
In the GMT800 community, it's usually adding a stepper motor and a tranny temp gauge, but replacing failing stepper motors are also common.
My final steps on setting the gauges were a little different.
I just thought it would help, in case there are some users that cannot get that last step of setting the needle correctly.
I am not at all indicating that my way is THE way, but it did work for me!
Good Luck!
Omar.
This link is compromised.
