1 - 1 of 1 Posts
2003 trailblazer_lt
Tools used:
1/4" ratchet wrench
1/4" drive 6" extension
1/4" drive 10mm socket
1/4" drive 8mm socket
mini pick
big pick (can use a small flathead screwdriver)
toothbrush
gloves (optional)
rags
can o' throttle body cleaner
Procedure: A more detailed step by step can be found here
remove intake box
remove throttle body
clean tbody
reinstall tbody/intake box
reset pcm
This is similar to the how to thread except I don't disconnect the battery to do the reset. I found a post here by mwfaith1971 which suggested removing the (2) pcm fuses (#10 and #28) for doing the pcm reset so I gave it a shot. It worked well. :cool:
1 - 1 of 1 Posts
