661 - 675 of 675 Posts
123k Miles
Well after 123K miles and banging out the old air filter every so often I decided it was time to give this a try. Now my truck ran okay (I thought) but it would sporadically stall with the A/C on and idle was rough with a little stumble off the line.
So today I pick a a brand spanking new air filter and a can of TB cleaner and went to town. I have to say I was surprised by the build up in the TB and even had to rub the thicker build up with a small piece of scotch pad to break it up. What a mess!
Anyway got it all back together and man does my engine run so nice, at first I kept over compensating for the stumble that used to be there haha, not a bad problem to have.
Great write up and great fix! The Blue Bomber is back on the roads and running smmmooottthhh!!!!!!
I bought a 2005 Trailblazer with 155000 miles. Ran very well but had a slightly rough idle. Since I have to get it smogged in CA for an ownership transfer, I changed the spark plugs hoping that would solve the issue. Had same problem, so went ahead and totally removed the throttle body (two plugs and 4 bolts) to clean it. It was seriously gunked up, worst Ive ever seen actually in all m cars. I cleaned it with TB cleaner and a toothbrush. I did have to manipulate and move the plate quite a bit to get it cleaned. Problem I have now is the car wont start after reconnecting everything. All the hoses/clamps are connected just as they were. It will start rough for 3-5 seconds if I hold the accelerator all the way down, but dies before it smooths out. I also get a small backfire. Something had to happen to the air/fuel mixture by cleaning the TB. Is it possible that I moved the plate too much while cleaning? I hate to spend $300 throwing a new one at it if I'm not sure. I did leave the battery disconnected for 45+ min, checked my fuses, and not getting any engine codes... I read somewhere that the IAC is inside the TB on the 05 Trailblazer. Is it possible that it is still fowled and not operating correct? Going nuts here... Thanks.
Hmm I don't know, this was a pretty simple process. Any chance you bent a pin on one of the connectors? Maybe try disconnecting the battery again and see if it resets?
2007 buick rainier
Thanks!
Great post, made the job very easy.
And wow does it get dirty.
The only thing I had a hard time with, is removing the tube the goes to the throttle body and the clip.
Once I found out, so simple.
Thanks again for a great write up!
(now I hope my P1400 goes away :)
Thanks for this. Thought I was up a creek after replacing my battery this morning. It now idles better than it ever has.
I just did this as well. But my 04 only has 105K on it but it was nasty dirty. I bet it was never done before.
Thanks for the writeup.
I'm sorry I know this is an old thread and I did not see the answer in the first few posts, but how often should this be done?
I don't know about the others but mine had 130,000 miles.
My first post, and this is the first thing I did with my '04 TB with at least 200k after I joined these forums. This was the easiest most bang for the buck fix I think I'll encounter with this baby.
I had to work mine over with a couple old toothbrushes and a bottle of carb and break cleaner until it was spotless.
Read Only
I forgot to add that the throttle body turned out NOT to be the problem. It was the throttle position sensor!
2008 gmc envoy_sle
Throttle Body
Used this thread on my O4 Envoy. Amazing car. I am sure it's on the road somewhere. It was old but perfect all original shape with 104K miles. I think totaled because of age. Boo Hoo.
Anyway, I loved so much that I got a used 2008. Lower trim level not loved much that I am trying to make work nicely.
Cleaning the throttle body is on my list, so definitely will use this again.
Great diagrams and easy to follow.
Thank you.
