1 - 14 of 14 Posts
hi this is how to add tweeters to your TB car with Bose sys after opining your Bose tap the wires as Brown yellow left side and dark blue /blue right side & solder the wires then tape them all now make a hole by 1 mm in the place where you see my pioneer instaled the left specker wire can be managed under the carpet to the left side i used the double sided Tape but first clean place you wish to stick the tweeter after all bolt every thing back you are done fyi .it takes 35-40 minutes to do this article
now the pics :crazy:
i might be wrong on this but you added 2x speakers so you halved the amount of power going to each. also, you cause a difference in the electrical impedance, therefore you did one of two things. 1. reduced the impedance even lower to cause more distortion or 2. increased the impedance reducing the power even further. :m2:
Do these tweeters have a crossover?
Gavin is right on one part if you don't have a crossover on them, it'll lower your impedance the amp sees.
Meaning you might have a 1 ohm load on those two channels. Which will end up being bad on the amp.
2004 chevy trailblazer_ltz
Hi Can I install another amp for a subwoofer in my TB ?
Hello
As I saw in this pics you have talent for improving audio performance
I install another power amp for a subwoofer in my last truck (00 Explorer) easily because there was a Pioneer cd Player with RCA subwoofer pre-out connectors, but the TB came with BOSE 6 cd player and I wonder if this system has the possibility (or have sub/pre/out connections) in order to perform the truck with an external subwoofer?
I would be glad If you show me if this is possible to do
Thanks a lot for your answer
If you have pics for installation, please let me know
Carlos calling from South America :tiphat
Bye :eek:
Discussion Starter · #10 · (Edited)
Hello
Bye :eek:
Its very easy to add an external amp to the rear pre amp signal i will get you the pics soon for the two pre amp sound wires so you can just join the wires to your new custom & re amp your original cars
Cd player plus your cars originaly amplified sound but dont blow your windows hehe just joking.
Thank you Alex !!!
I will be waiting for your pics to install the power amp & sub !!!
Gracias !!
Carlos from South America :tiphat
Gracias !!
almost easy as burger .your bose has 2 conecter one is 24 pin go for it
24-pin connector:
left audio pre amplified by cars audio switch
A9 - Left (-) dk green
A8 - Left (+) tan
right audio
B10 - Right (-) org / blk
B11 - Right (+) lt green
now just join them to your custom power amp & sub .
good luck
Thank you Alex !!!
Where is that 24-pin located?
Sorry for my English Vocabulary but what color is "tan"
Any pics? That would help me a lot
Gracias Nuevamente Amigo Alex
1 - 14 of 14 Posts
