This was completed on a 2003 Trailblazer EXT LT
Proceed at own risk!!!
The Directions below were done with the parts and tools below. If you decide to use a different part or tool, these directions may not work.
Parts and Tools needed
Tools:
• Phillips Screw Driver (shorty; needed to remove 3rd Brake Light),
• Miniature Flat Head Screw Driver,
• Dremel/Rotozip with drill bit
• Razor Blade (New Blade)
• Wire Cutters
• Wire Strippers
• Soldering Iron
• Solder
• PVC Glue or adhesive product
• PVC Glue Primer (only needed for PVC Glue)
• Metal Straight Edge (if using plexi glass)
• Duct Tape and/or Clamps
• Ruler or Tape Measure
• Air Compressor with Nozzle (blow out debris from inside light), Compressed Air should work the same but you may need more then 1 can.
• Standard Flat File
Parts:
• 9” LED 2 Pack (Advanced Auto Parts)
• 3rd Brake Light
• Silicone or Gasket Sealer
• Acrylic sheet or similar shaped “bracket” (19” minimum recommended length)
• Extra Wire (20” should be sufficient / 20-22GA)
1. Open the whole tailgate (If in a garage watch out for overhead clearance)
2. Pull weather stripping down from top center by the rear dome light. This should expose the space between the roof fabric and the top of the truck.
3. You may be able to see the connector that goes to the 3rd Brake Light. If not, lightly pull down roof fabric, it should just be lying on top of the roof fabric.
4. Take the Miniature Screw Driver and gently pry up the top of the female connector, then pull the male side to free the Brake Light connector.
5. Push/Pull the rubber sealer/wire up through the top of the body.
6. Lower the tailgate, unlatch the window from the tailgate. Do NOT open the window if in a garage with low clearance. If not in a garage or if there is enough clearance, you can open the window, then lift the tailgate back up.
7. Unhook the wire from the clip where the plastic bezel and body meet, then push the wire up between the bezel and body the best you can.
8. Lower the tailgate, open the window and firmly pull the cable up through the space. This may take a few tries if it snags on the hinge or you were not able to get enough wire through the space.
9. Unhook the wire from 2 more clips
10. Take the shorty Phillips Screw Driver, while holding the brake light, unscrew the 2(in our case) screw from either side of the brake light. Some may have a 3rd screw in the center back of the brake light.
2 9" LED Strips from Advance Auto Parts
If you can find an 18” version of this it should work the same. If it is not the same type of light I cannot promise it to fit without more drilling.
3rd Brake Light.
The 2 screws shown here can stay screwed into the housing. You can also see where the 3rd screw might be if it is used on the bezel.
Preview of Mirror Acrylic.
Camera shot of the Mirrored acrylic I am using. I had left overs from a 4x8 sheet I had ordered a while back from Home Depot. You should be able to order/buy this from MOST hardware stores. This acrylic is 1/8” thick which is why I doubled it up. If you don’t want to use acrylic, you could PROBABLY use a thin piece of metal in place of it. Make sure it is really clean before sticking the LED’s to it though. Same for the acrylic but it should be clean if you left the protective sheet on.
Holding down Acrylic for Cutting.
Using clamps at the edge of the table is probably more acceptable but I didn’t have those. I used duct tape to hold the ruler to the acrylic, then once in place, taped that to the table. The big silver square is a computer case side I used to help me hold the ruler from moving (even though it is all taped down).
TAKE YOUR TIME!!! TAKE YOUR TIME!!! TAKE YOUR TIME!!!
You can see my scoring marks I did already with the razor blade. Make sure it is a new and clean blade before starting. You will be more prone to cracking or not cutting in a straight line. For your first score of the acrylic, GO SLOW to ensure a straight line. Rushing this part will GUARANTEE it to crack and break. If you veer off your straight line, try coming from the opposite side to correct, you probably only scratched the protective layer (you do still have that on, right?). Once you get a few scores done, you can run it along the straight edge a little faster. DO NOT try to force the razor blade to cut the Acrylic, this will also cause cracking. Try to use an even light to VERY moderate pressure. Once you think you are getting close or hear the first part of it break (good break), use only light runs with the razor blade. Forcing it at this point may cause it to shatter. It took me a good 45min or so and I still cracked it because I got excited at the end. I was able to use it because it did not crack all the way through. The reinforcement will help this too.
SAFETY GLASSES RECOMMENDED
CAUTION!! WHEN USING THE DREMEL, WATCH OUT FOR THE CATHODE BULB. WE DO NOT REMOVE THIS. CAUTION!!
Dremel, bit and cutting brake light.
Almost any cutting bit should work for this. I used one that was already in our USED box. Being that this wasn’t a hard surface like wood, I didn’t have a concern for what bit I used. There is minimal force needed to cut out the area of the brake light. Start the dremel in between the red lip and black lip. Grind the red until it is smooth with the facing. You will have to grind out some of the black plastic to get the whole assembly to fit. It should have some form to the shape of the letter “D” but more like |). This will have to be done on the opposite side as well.
Checking Clearance of Acrylic in Light.
Once you have cleared the opening in both sides. Check for clearance to make sure the strip of acrylic will fit. You just need to make sure one will fit at this time. If 1 doesn’t fit, it won’t matter if 2 will or wont. With my piece of acrylic, there were some spots that didn’t break off (seen in blue oval). You can file these off until it is all as even as possible. If it seems like there is still a little too much force needed, take the dremel and grind out the top of it a little more. LESS is MORE in this case. If you make the hole too big, the LED’s may not sit correctly or take more work to get them to sit right.
Acrylic in Light.
Once the holes in the light allow free movement of the acrylic, slide through one side with reinforcement piece (if needed) and LED strip. Do NOT tape or glue anything together yet. You are just making sure the clearance for everything is good at this point.
As you can see in the light, all the plastic shavings. This is where you would take the canned air or air compressor and clean out the light. I used a 20Gal 5HP compressor (obviously overkill but did the job nicely). Once it is free of debris, you are done with that. Do NOT use water!! The LED’s are not made for outdoor use! You can get canned at at almost any local computer store or retail store like Wally World.
Glue used to hold Plexi together.
This was what we already had in the house so I used it. Be careful with these products. The Purple Primer will stain whatever it comes in contact with. We laid a piece of cardboard down (as seen in picture). The glue does not take very long(15-30sec) to start drying.
Apply Glue Primer, Apply Glue next. Do quickly or glue will dry.
When applying primer, wipe off as much as you can on the brush. It does not take much to prime these pieces. Again, caution, it WILL stain anything it comes in contact with! Remove the plastic from the reinforcement pieces if used. I primed both the back of the acrylic bar and the reinforcement pieces. As you can see it “eats” away at the gray backing (pink spots). Do not worry, it does not harm the mirror finish. Put glue down on back of acrylic bar. You do not need huge amounts, just enough to lightly coat the back. Set reinforcement pieces on back, press firmly down for a few seconds. Wait 30sec to 1min before continuing.
See next post.
Tools:
• Wire Cutters
• Wire Strippers
• Soldering Iron
• Solder
Parts:
• 3rd Brake Light
3rd Brake Light.
Acrylic in Light.
See next post.
