1441 - 1460 of 1472 Posts
2006 gmc envoy_sle
We bought his and hers 06 Envoys new. Sold mine last year with 178,000 miles. Bought wife a new car, driving her Envoy now, it has 28,580 miles total. Both have been very reliable.
2002 gmc envoy_slt_xl
Thought I would chime in:
02 Envoy XL with 250,000 miles on her. She still needs a lot of TLC for stuff that is failing. I have replaced most of the engine components short of replacing the engine itself. New transmission at 240,000 miles because it decided it no longer loved life and grenaded itself.
Actuators (like most) need to be replaced and the rear HVAC stopped working. If anyone could point me to the thread that shows how to fix it that would be awesome!
2005 gmc envoy_denali_xl
2005 Envoy XL Denali with 314K
Rebuilt Transmission at 220K
I Replaced
  • Fuse Box
  • Water pump
  • Air Suspension Bags 2x
  • Left Motor Mount
  • 3 Igniters
  • 1 wiper fluid pump
  • shocks
  • tires 4X
  • Brakes (rotors and pads) 5X
  • Driver seat cusion
  • Plugs and wires 4x
  • Upper A Arms
  • Right front axle
  • Fron Wheel Bearings
  • Fan Clutch 2x
  • Serpentine Belt 2X
  • Oil/Filter every 5-7K
  • Clay bar and wax 2x per year
  • fron differential engagement assembly
Now a check engine and the oil pressure problem. Probably the o-ring.
Car in great shape otherwise with no dings, no rust,
Probably donate it. Sigh.:tiphat
2005 chevy trailblazer_ls_ext
Loofa, what were the symptoms when you replaced the fuse box? And did you have any trouble matching fuse boxes? Mine has been in the shop 3 weeks now and they are telling me they are having a hard time finding a fuse box to match it. Thanks.
I Replaced
  • Fuse Box
  • Water pump
  • Left Motor Mount
  • 3 Igniters
  • shocks
  • tires 4X
  • Upper A Arms
  • Right front axle
  • Fan Clutch 2x
2008 gmc envoy_sle
local scrapyards should have those in stock.
try ebay too.
The symptoms were that the car died on the highway 100 miles from home. I had it towed it to a dealer and of course it was OK. They suspected it was wiring near the fuse box.
I drove home and it died along the way again. I wiggled the fuse box and it started.
Drove it for a few weeks periodically wiggling the fuse box.
Took it to a more local dealer with my story and they said the fixed it. ~$ 500.00
I drove away and it died 20 min later. Wiggling did not work so I towed it back to dealer.
It started. F**k
They this time removed the fuse box and found lots of corrosion underneath. They special ordered it and replaced it. No problem since. This was about 2 years ago.
If you are at an independent shop, I would call a dealer and give them your VIN. Dealer should get a proper GM number for your car. I would have done it myself but I could not for the life of me figure out how to remove it without breaking it.
Thanks man that helps a lot I really appreciate it. Sounds like the exact same thing wrong with my 2005 Trailblazer.
I have it at a shop around the corner from me but they are acting like a bunch of amateur hacks. They said they would find one by Friday but it's been there since Nov. 28. I'm going to get it Friday whether they have one or not. This is why I try to do most of the work myself, I only took it to them because I didn't have time to fix it. If I had known it would take them three weeks I would have just kept it in the carport until I had some time off.
It started. F**k
2006 gmc trailblazer_ls
Just got my 06 denali back from body shop tonight after i hit a deer. Im at 140440. Planning on next upgrade being exhaust. Already did resonator delete but planning on having a borla proxs welded in place of the stock muffler here soon. Then coil spring conversion in rear, spacers and probably some 265/60/18 on stocker wheels. Maybe possibly a lift
08 GMC Envoy
I bought the 08 Envoy for $1000 a couple months ago at 176xxx miles. Since then I have put at least $500 worth of parts in it myself, thanks almost entirely to this site I may add (Thank you all!). This is on top of the $2000+ worth of service history records I obtained from the past 3 years, making me think it shouldn't have too many problems when I bought it (a few, sure). Man was I wrong. I have been amazed at how every time I go to fix one thing, I find several more that need fixed, haha. I have replaced: front passenger hub (fixed service stabilitrac/abnormal abs activation problem caused by bad wheel speed sensor, and I noticed a little catch in the wheel bearing after taking it off), Evap solenoid/canister (fixed check engine light, lol), cam position sensor (fixed different check engine light...), blower control module (fixed fan not blowing half the time), battery (new battery has went dead a couple times so there must be a drain somewhere at times...haven't found that yet), and tires (pretty routine!). I am now in the process of replacing driver side upper ball joint and tie-rod end, as well as passenger sway bar link (cannot for the life of me find one that matches the one that came off:mad:), cv shaft, and wouldn't you know it!?!?......the front axle disconnect (seal/bearing that holds cv shaft completely gone :eek:). Luckily I bought the whole unit, because (as my luck goes) the old one broke off inside its hole in the oil pan!!! This was a PITA to extract, and after a few nights of drilling, die grinding, and hammering, I am quite proud to announce that as of tonight the POS thing is successfully extracted! Now to cleaning it up, putting the new one on, and putting everything back together (so I can go on to fix the ball joint and tie rod end....and likely the next problem(s) I find with this pile:crazy:. Overall it's a pretty nice vehicle though! Haha. Okay, so I'm a Ford guy, but this thing has done nothing but remind me why I'm a Ford guy. It also says service airbag on the dash, but I don't even know where to start with that...and the TPMS sensors are gone (has TB wheels lol). At least it has heated seats...for now.
Bought mine in June and ran fine until Thanksgiving. Put about $2k in parts/labor because I just haven't had time to fix myself. The big one was a fuel pump that I just didn't feel like doing all the work. This thread has helped educate me a great deal but I think I am selling mine and getting a 4Runner.
Years and Miles
My 2005 Trailblazer 4WD has 117,900 miles on it. I use synthetic oil and change the oil and filter every 5000 miles, along with tire rotations. I have had extremely good luck - no major issues ever. No squeaks, no odd noises, no problems with the instrument cluster, never had any engine problems, Nothing!! Just normal maintenance stuff, that's it.
2008 gmc envoy_slt
Just clocked 73K miles on my 2008 Envoy. Runs great, replaced all brake rotors, pads at 60K. Running synthetic oil, change at 10K. Averaging 17 mpg, 3mpg better than the ‘89 Explorer AWD V8 that I had before the Envoy.
My lovely 😊 pewter metallic trailblazer LT has about 227k miles . Let me tell you this beauty is a beast. I’ve had the transmission replaced at 190k but the engine is still running strong. My parents think I’m obsessed with it and say that I need a new car. I’m like forget it, I put so much work on my baby I don’t think we’ll ever get rid of it . I’ve done some minor tweaks in mostly all aesthetic. New Hids , updated bumpers. Led lights on the inside. Small things that we trailbleezy peeps would notice. I’m currently wanting to get a Flowmaster/magnaflow installed, might actually do it tomorrow depending on the weather since it’s cold as hell down here now. But but to answer your question, 227k and running strong!
2008 gmc envoy_sle
hi and welcome.
what year and color is your TB?
