2008 gmc envoy_slt
During acceleration, I have a vibration throughout the whole vehicle. When I let off the gas the vibration stops. The vibration is nothing violent, but very noticeable.
Thank you,
Bryan
With the vehicle safely on stands, in neutral with park brake off...
...grab the drive shaft on each side of the U-joint with your hands and rotate opposite alternating directions. If you feel ANY slack the U-joint is bad.
Grab the shaft near the U-joint and push up and down, ANY movement in the U-joint and it is bad. Not to be confused with looseness at the spline at the transmission tail shaft, although if that is real loose it too can cause vibration.
