I have a 2002 trailblazer LS, started it, no problems, idle was fine even when in drive, then when I pulled out into the street and went to accelerate, it’s like it didn’t want the gas or want to accelerate. It’s done it a couple times. Please help
i never said anything about reverse. I back into my parking spot at home. It’s just once a day that it happens and many people have told me it’s the throttle bodyOK --- new list....
Because you said that it backed up OK - then we have to suspect the only thing that changes when you choose to go forward - the transmission. --- maybe.
- The transmission is starting out in a higher gear than it should - might be an electrical problem with a shifting solenoid inside the transmissio.
- I'd start there ↑ - because i'm not there where you are and I cannot test drive it myself.
