1 - 8 of 8 Posts
Hi,
I just bought a 02 trailblazer LS.
I found a small problem: sometimes (maybe 1 in 5) when I start the engine, the RPM is high (11000 RPM while normal is 600). And I can hear obvious noise from the hood especially if I want to accelerate. It will disappear after a while, or if I stop it and stop it again, it will be fine.
Someone on the forum said it is due to cold, but here is not cold now around 80 degree. And someone else said it is due to the fan clutch.
Can anyone give me more information?
thanks a lot,
From my experience, when the weather begins to get hot, even after sitting in a parking lot all day, my fan engages fairly heavily for the first few blocks. I have not heard the telltale "clicking" that other clutch failures have made...
But I agree, when the engine is "cold" just after start, the RPMs should be a bit high and slow down as it warms up.
· Banned
The programming in the PCM includes a table of desired idle RPM versus coolant temperature. It might be slightly different for your year, but here's mine (observed with EFILive tuning software):
The noise is the fan clutch, and sometimes (not always) when you park it, the silicone fluid drains differently. It's not a problem unless the noise extends more than a couple of minutes after you drive off.
Search for a thread called "Fan Clutch 101" for more details.
1 - 8 of 8 Posts
