1 - 13 of 13 Posts
I have a problem with my lights. The low beams, (also attatched to the day time lights) no longer work, also the fuel gauge doesn't work either. I have a friend that has a shop and he plugged it up and found no codes anywhere. He feels like it may be the bcm? Anyone have any ideas or fixes?
low beams, day time lights, and fuel gauge don't work
anyone have any ideas? i have checked all the obvious things and everything checks out. It is also not throwing any codes off...
welcome! hmm off hand im not too sure..for the headlights check the fuse under the rear seats, theres a chart on the box with the fuse/relay layout
hopefully someone else will chime in here as well
....probably should have title this as an Intro thread :undecided:duh:
:tiphat Welcome :tiphat Try relay #46 in the fuse box in the engine compartment. Switch it with IIRC #44 or #45 to see if the lights work. If the lights work, replace the relays and go to a parts store for a new one.
2008 chevy trailblazer_ls
Welcome to the site!!!
1 - 13 of 13 Posts
