2008 chevy trailblazer_lt
Can you pros out there tell me if an older RF P100.2 amp will work with a 2 ohm load? The specs tell me it will work at 2 ohm loads on a per channel but when in MONO it says it's 4 ohm. I'm trying to use it to power a single Alpine DVC 10" sub that only shows me how to run at 2ohms. Can I use this amp or should I get a newer one that runs at 2 ohms?
Thanks.
2003 trailblazer_lt
Thanks.
2 ohms bridged will make that amp blow up
is there dual 4 ohm coils on that sub?
