1 - 10 of 10 Posts
HELLO ALL- I NEED SOME ADVISE- MY WIFE HAS A 02 TRAILBLAZER 152K LOV E THE TRUCK BOUGHT IT USED IN 2003- DISCOVERED IT WAS IN AN ACCIDENT-- SERVICING THE VEHICLE THIS WEEK AND INSPECTING THE UNDER CARRIAGE AND I NOTICED THE DRIVERS SIDE READ UPPER CONTROL ARM MOUN TO THE FRAME IS ROTTING / RUSTED- WHILE ASSESSING THE EXTENT OF THE DAMAGE I NOTICED IT WAS VERY BAD-- LOOKS LIKE SOME ONE HAD PAINTED OVER IT ORIGINALLY - PERHAPS WHEN IT WAS HIT--- ANYWAY- NEED TO KNOW IF I CAN FIND A BRACKET TO BOLT ON OR WELD TO THE FRAME... OR IS THIS A PURELY FABRICATION PART? ANY THOUGHTS? I WOULD REALLY LIKE TO KEEP THE TRUCK AROUND--
:cry:
It was my understanding from many years ago that you couldn't weld on a patch to fix a control arm mount issue like that. Only a new frame part would do. GM sells that front part of the frame specifically for those sorts of repairs. A body shop could tell you for sure. We used to know of a resource with that sort of exploded parts views, but alas, they died.
It's on the frame in the rear--- just behind the read drivers side door-
not the front--
perhaps i could fab a bracket and bolt on to the frame???
I was just wondering if anyone ever found a fix for this issue?
I have been hearing a rattle in the rear end of my 02 trailblazer.
After some investigation I have the same issue as mentioned above.
Stopped at a body shop on the way home from work yesterday and they said it can’t be replaced as its part of the frame.
Bad news to say the least!!!
Only have 106K on it and is in great working condition otherwise…
Thanks
2003 chevy trailblazer_ltz
funny same exact thing on my 03 trailblazer ltz
I hooked up a small trailer
and heard a crack
rusted rear trailing arm broke right of
upon further inspection, the upper mount is all sorts of rusty
drove it like that for a while but threw my allignment off
and caused my tires to wear quickly
and my shocks are bad too.
Still paying on the car, and this happened before my 12th payment.
Dealer said not covered at all under warranty.
seems to be a common problem
I did get a new arm installed but there was no guarantee it will hold
I plan to have a friend weld a plate to secure it better
and hope it holds as I bought this SUV to tow my small camper
living in upstate NY provides a rusty under carriage though....
same thing happened to my '02 TB. Heard a clunking noise and it really started getting loud as I reversed out of my driveway over the curb. I saw that BOTH of the Upper control arms had snapped in half at exactly the same place! When I removed the drivers side arm, the inside of the frame looked like swiss cheese. Very rotted out. And the plastic gas tank is on the other side of the frame, so welding a patch onto the frame just got more expensive. My fabricator buddy is going to McGyver something to make it work
Thanks
I had a fabricator take a trailer hitch sleeve and cut in and weld L brakes to the bottom of the mounts for mine. My driver side was broken off and the bottom mount on the passenger side was gone drove. It for 12k miles like that till I got it fixed.
I had a fabricator take a trailer hitch sleeve and cut in and weld L brakes to the bottom of the mounts for mine. My driver side was broken off and the bottom mount on the passenger side was gone drove. It for 12k miles like that till I got it fixed. Cost me $280
1 - 10 of 10 Posts
