This is my first post to this forum but have used it many time for information and have really liked the peoples help and advise. I have a 2005 TB ext LS. I have had it for several years and love it but a couple of days ago my left turn signals went out and no bulbs or the dash light will light. When i turn on the emergency flashers only the right side works. I have changed the flasher relay and the multi switch on column. After that did not work I decided to actually do the troubleshooting I should of to start with. I do not have any voltage at the bulbs, bulbs are good, switched the circuit boards in tail lights and problem stayed on the left, fuse is good in rear fuse box, using a trouble light type tester instead of volt meter at the output of flasher relay causes a fast flash of the trouble light and flasher, no voltage on the left turn fuse in the rear fuse box, after looking at what diagram I could find means I have lost connection between the flasher and the fuse box or a bad fuse box. Any idea where to start looking for a bad connection or does it go through the BCM to the fuse box or does it go through the BCM at all.. I can not find a schematic for the entire circuit.
I live in Tennessee and most of us don't use turn signals to start with, but I am one of the oddballs here who likes to use them any help would be appreciated.
