1 - 3 of 3 Posts
Hi
I asked this same question under a much earlier thread - but thought it best to try this with a new thread. I get the codes above (C0305 - Front propshaft speed sensor, C0306 - Motot A/B ckt malfunction and U1255. The vehicle cyl 1 misses and I can't figure out what the issue is. Replaced the ignition coil, new plugs, move plugs and coil around and the #1 cyl still misses and the codes just come back. So, what does the group think the problem is here - or do I just go to a Chevy dealer and have them diagnose the problem(s)?
2003 chevy trailblazer_ltz
I had issues like this earlier this year giving mine a tune up. A video said it had something to do with me disconnecting the battery and the computer thinking it's dirty or something I wasn't really sure,
But, after cleaning the throttle body and reconnecting the battery the computer reset and everything went back to normal.
Checkout u tube that's where I found the video. I faintly remember having to reset the computer somehow.
Sorry I couldn't be more help but that sounds like the problem I had. I even changed coil packs,
If the misfire does not move with moving the coil or changing plugs, the problem could be a bad injector or a valve issue. Do a compression check on all cylinders to determine if cyl #1 has good compression.
1 - 3 of 3 Posts
