1 - 7 of 7 Posts
2004 chevy trailblazer_ls_ext
i am thinking about purchasing 2 sets of the 36" LED strips from Oznium and mounting them under the running boards on both sides of the TB. I want to wire them to the dome lights so when i unlock doors from key fab or open the doors they come. My question is with running 72 LEDs off that fuse/relay will that be to much or will it work ok?
thanks in advance for the help.
I think it should be ok. That is the beautiful thing about leds. They take very little power and also produce very little heat.
you should be ok but you should just use a relay to play it safe. If you knew the draw of the strips(amperage) that might be a little more help full.
:iagree:
You will be fine. You are talking about 1 to 1.5 amps (if that much). There is about 3-4 extra amps on that relay.
1 - 7 of 7 Posts
