1 - 3 of 3 Posts
Hello guys,
It's been a while since i posted on trailvoy. The reason I made this thread is because I'm interested in switching from my chrome rims to off-road tires and also wanting a lift to go with that. I am brand new to this area, so I apologize for the questions. I did take a look at this: http://jd.offroadtb.com/modifications/index.htm#Bumper
1. I am interested in lifting my tb. I've been looking at markmc's site, I think I will go with the 2.5" lift/level kit. My question here is: Is it necessary to buy new new shocks or springs with the lift?
2. I think the size of tire I want is a 33, so I will need a wheel spacer for extra clearance. If clearance is still an issue, is it possible that you could use both a spacer and adapter?
3. Do I have to get PCM reprogrammed? due to the bigger wheels?
All the questions for now,
Martin
2003 gmc envoy_slt_xl
i can answer a few
I put a 2.5 leveling kit from Summit Racing on my 03 envoy and 30's and I had to put wheel spacers because it rubbed, I had to get it aligned.
2007 chevy trailblazer_ss_3ss
The kits are designed to be used with factory struts, shocks and springs.
However, some guys upgrade the front struts to HD Bilstiens and rear shocks to skyjacker #N8030
Combining wheel spacers with adapters is not recommended.
Wheel spacers should give enough room to run a 11" or 11.5" wide tire.
most common are 265/70/17
hit me up at my gmail for more info.
note:
You can probably find a cheaper kit from another vendor or ebay, but you wont get the customer service i provide.
1 - 3 of 3 Posts
