1 - 20 of 37 Posts
I have suffered from the almighty bad fuel pump, bad fuel level sender catastrophe and I had an off the wall question. I dont know if i am going insane or not, but if you look at the picture below, which is where the gas nozel goes, I almost swear there use to be a silver flap i guess for air pressure or to help overflow.
I was wondering if i am crazy or if it really is missing? Does anybody else have a flap there?. If it is indeed missing it might be causing a negative air pressure or heck even jammed somewhere in the tubes... I dont know...It might be a long shot....
Any help?
2002 olds bravada
it looks like it fell into the tank. You're still probably under warranty so take it to the dealer and have them look at it.
HEH... Silly me... The car is still under warranty. PHEW!!
Ill make sure to mention this when I take it in tomorrow to get the fuel pump replaced. Thanks everyone!:woohoo::woohoo::woohoo::woohoo::woohoo:
2007 chevy trailblazer_ss_3ss
i saw your post and decided to take a look at mine.. i have the 5.3l envoy. and low and behold.. I don't have one either.. let me know what the dealer do to fix..
will not having this silver flap have adverse affects on the fuel system, egr system, or fuel milage.
2004 gmc envoy_slt_xuv
Any help?
Dont panic guys...the removal of the flipper was a running change on the GMT 900 in april 2006. I am sure it could have occured eariler for the GMT 360 / 370. I specificly remember asking how this change could not have a negative effect. Apparently it was a early EVAP countermeasure that is no longer needed with a modern fuel system. Cost savings to GM 65 cents per vehicle.
Its OK!
2002 olds bravada
the dealer would probably just replace the filler neck. I don't know if its that whole assembly or just that part. I'm not sure about the v8's but the I6's do not have EGRs. IMO, it would probably allow gasoline to evaporate easier, causing more gas consumption. But i don't know whether or not it'll affect fuel pressure.
Don't you have a warranty as well? lol
2006 gmc envoy_denali
Another 06 Denali here. I don't seem to have it either:bonk:. I'd have to guess they were never there to begin with:weird:. Looks a little weird:crazy:
Dont panic guys...the removal of the flipper was a running change cost savings not needed
I think the gas tank filler neck flapper valve was for sealing the top of the filler neck if the vehicle was in a crash that separated the top of the filler neck from the gas filler cap in the event the vehicle was rolled off it's normal upright postion. It's to keep fuel from running out of tank if the vehicle is upside down.:duh:
Its OK!
Tell them one more time.:D
No, that is what the cap does.
The flap may slow the gas in a rollover or tip over if the cap is not on. But it will not stop the flow completely. If you look at the bottom of the picture , there is also a small hole for gas to drain into the tank if you have the flap and try to over fill the tank.
Its OK!
Thanks for that information. I've wondered that since I first noticed it several months ago.
Discussion Starter · #18 ·
Well I got the car fixed and they did say they found the flap in the tank... PHEW i wasnt crazy. But i guess they didnt deem it important enough to replace it since its still gone. BUT YEAH! GO GO GADGET WORKING FUEL INDICATOR!! :thumbsup:
i always thought that thing was in there to keep people from siphoning gas out of your gas tank.
OK are the i6 suppose to have the flapper and not the v8?
1 - 20 of 37 Posts
