Gas in oil pan, oil on plugs 6-4
14K views 12 replies 8 participants last post by  91RS
Maybe oil fouled plug not firing consistently and the fuel washing down the cylinder walls and diluting the oil? Only problem with that diagnosis is that it should have set a code
The injector might be leaking after shutting down and washing the fuel down the cylinder walls. Whatever is causing it I wouldnt be driving it until you fix it because not only will you scuff up the cylinder walls but you will also end up doing in your crank as well.
