21 - 31 of 31 Posts
Discussion Starter #21
can you get a pic of the wires that you cut into for the highs? im installing this and wanna get it right
It is all taped up and sealed. Just look at the wire color diagram, its pretty easy. The wires are THIN, but don't worry too much of you cut the wrong one, it can simply be joined back.
well we are looking for where to tap in, you said to take the battery out and there is a dark green/white, and a light green/ black, we see those 2 wires at a plug. we just want to make sure that we attatch to the right wires, we dont want to have to follow wires all the way from the headlights.
this is right next to the fuse box under the hood. were trying to figure out if those are the 2 wires your talking about for the high beams, or if we just need to follow the wires from the bulbs back
EDIT : we got the battery off and have access to the harness unterneath
ok, we got it, sorry for the multi posts, we were just trouble shooting while installing. Just so everyone knows, there are TWO light green/black wires in the harness, we connected the wrong one first and the lights didnt work, and then switched it to the other light green/black wire and it worked, so it would have been easy if we just choose the correct wire the first time, but its a 50/50 chance of it i guess
Yeh, I know, Ive been a Lurker forever...but just now came upon some play money...that, and I've only had my Trailblazer for a year, I joined before I owned one. I guess this is the easiest mod to do...you gotta crawl before you can walk and so on...
Yeah,i prefer lurkers over noobs anyways,they generally are smart,ask meaningful questions and dont hijack threads,whereas noobs are usually...retarded.
Mine should be in soon,but since im not trying to clear traffic with them,i will be hooking them up to my auxiliary lighting on my bumper,so they will not be nearly as bright.
2003 gmc envoy_sle
I got the Galls Traffic Backer the other day and the old man and I are putting it in tomorrow. Should be interesting after looking at all the damn wires coming out of the control module:drool. Hopefully ill get some pics and put them up. I like it alot better than the front wig wags, and the one i got does the brake and reverse lights at the same time.:woot:
I used this Flasher for a Couple of months I found it to Work Just Fine But I wired mine A Little Different, I put it under the Hood Constantly on and Ran a Seperate Power Wire to my Carson SC-1022 Worked like a charm and No Huge Box inside the cab!!! Nice Install Looks Clean Too...:thumbsup:
If you are concerned about messing something up, or like me, just hate cutting factory wires, you can use a headight harness extension for your install. Just splice the HLF wires into the extension, and then plug the extension in between your factory wiring and headlights. That way down the road, you can pull it back out and it's like it was never there! I found an extension on Ebay for $15 for a pair...
http://www.ebay.com/itm/9006-Hipro-Power-Headlight-Bulb-Harness-Wire-Connectors-/190495475573?pt=Motors_Car_Truck_Parts_Accessories&fits=Model:Trailblazer&hash=item2c5a6a4775&vxp=mtr
Good luck!
Here's my problem, the flasher unit that I have only has two wires, blue and yellow, for each side of the high beam. Of course there is the white wire (12v), green wire (ground), a red wire (12v Switch), and a black wire (parking lights) for nighttime disable. The diagram shows only to cut one wire and splice the blue wire to the driver's side and the yellow wire to the passenger's side. In this thread, you referenced two separate wires. Can you explain the wiring diagram in detail about those two wires in the harness? Does each wire power each high beam? Or does one wire power the low beams and one wire power the high beams? I had this flasher unit hooked up in my Ford F-150. It was a one wire cut with the blue wire spliced in to the driver's side and the yellow spliced in to the passenger's side.
21 - 31 of 31 Posts
