Hi Folks; My 2005 Envoy 4.2 had a rusty fuel pump / sender that leaked and had to be replaced. I had my trusted shop replace it as I was not looking forward to dropping the tank. The car was hard to start with the new (Spectra, I believe) unit. It turned out that the internal check valve was bad. The pump was replaced with another unit of the same make. Still hard starting. I was told to let the fuel pump run for several seconds before cranking. Not happy with this, I requested the pump be changed with a different brand. This THIRD pump was OK for approximately 10 months but now the car is hard starting again, particularly bad if the car is hot and an hour our two have passed since shutoff (vapour lock?)
Rather than change the fuel pump yet again, would it be possible to install an external check valve in the fuel line?
Thanks, Peter in Canada, otherwise loving my Envoy!
