I removed the vapor canister vent valve to test it, before removing the tank. I couldn't get it off for nothing by squeezing like your supposed to. So I got a flash light to see what was up and both side connectors are broke free, see the drawing below. Can I use the connector as is? Can I replace just the connector (is in on there good and strong and not sure there is enough hose to cut it off). Or do I have to replace the whole hose?
I tested the vapor canister vent valve and I think it intermittent/bad. It only closes/opens reliably in one position. If you spin to different positions sometimes it works and sometimes it doesn't. Also, not sure if this is normal, but when it does close and you blow on it, it won't open back up when you remove electricity until you stop blowing - like the pressure is keeping it open - not sure if that is normal or not.
vapor canister vent valve:
vapor canister vent valve connection:
