I have an evap code P0442 which I thought was due to a bad fuel cap (old one had a cracked O ring). Replaced it and light was out for a couple weeks. Light came back on recently. Also around the same time I was smelling fuel after filling as if I had spilled some, but I hadn't.
Long story short I found that my filler hose or neck is leaking right where they are clamped together. The hose is also kinked there (been that way since I got it) which has made it a little harder to fill up at times. Well, this is the last straw, so time to replace the neck and the hose.
Problem is, Compnine is down so I can't find the part numbers there, and the only part numbers I have found on here are for the EXT models as in the sticky above. Anyone have the part numbers for the 02 SWB with the 18 gallon tank by chance?
