1 - 12 of 12 Posts
Front wipers only work on high and you have to time turning them off so that they lay flat. I thought it was the switch so I replaced that. Same thing. I read that it was the relay so I switched the relay (#42) marked something like "WS/Washer" with the one next to it. No difference. Any suggestions on what else may be causing this issue?
Thanks
If you have a pick-a-part near you just go grab another wiper/motor module. There are a couple of causes but it's usually easier to just try another one.
There is a grease inside that sometimes gets all over the electrical business is one issue.
2007 GMC Envoy SLE
Thanks
i have the same issue. Was told it’s the motor by my mechanic.
A mechanic would say he'd replace the PC Board and that it'd be fixed. Even Dorman has a "FIX" for it in their list.
It's a common problem and a mechanic would know that.
Mechanics attend a lot of seminars, read a lot of books and magazines of the trade, talks to his mechanic buddies and this has been a hot article for years.
A PARTS CHANGER would sell a whole motor - which contains a reman or new circuit board anyway.
After 55+ years as a mechanic, I resent people who "sell parts".
2002 olds bravada
Thanks
it is the grease causing this, it has been posted here before, a symptom is that on intermittent wipe the wipers do not self park and stop erratically during their sweep. Clean the grease off the circular contacts and the other parts that runs around the circle (called a wiper). I have had to do this twice on my 2002 Bravada
It looks like a circuit board isn't available - but Google this part number for a complete motor assembly:
Hold on - editing now for CORRECT part number.....
WELL ----> THAT was enlightening! I cannot even find a new or rebuilt wiper motor let alone a wiper motor module!
I can get rear wiper motors (40-1038) but not fronts!
The circuit board is sold separately.
Please see the photo below.
However, if you want to buy a motor, then it will be delivered assembled (motor + circuit board)
Keep in mind that the wiper mechanism is different for different years, please check the VIN of your car to buy a suitable spare part.
Discussion Starter #11
What is the part number for the circuit board alone?
Unfortunately, I do not know the year of manufacture of your car. There are cars with and without a rain sensor, for each of them the circued boards will be different. You need to check the details according to the VIN number of your machine.
1 - 12 of 12 Posts
