2003 chevy trailblazer_ls_ext
this is my first time posting so excuse me if I make some mistakes, so here is the problem the front tires spin wont spin when I put the truck into a4wd, 4hi or 4lo, I do not have a 4x4 service light and I can hear the 4x4 engaging underneath the truck, so the first thing I tried was I replaced my 4x4 front actuator and that didn't no fix the problem then I tried pulling fuse #8 under then hood then I jacked the front end of my truck up and put it into 4hi and 4lo and both of the front tires spun freely and I heard that no supposed to spin when doing so, I don't know what else to try and my truck doesn't make any grinding or scraping noises when driving
4x4
my truck is doing the same any help would be great. things I tried
1.my light on switch looks to be working correctly.
2.no service 4wd light is on.
3.both the front axel actuator and encoder motor sound like they are working.
4.I jack the front left tire up in air put it in part start truck and put in 4x4. then o turn the tire by hand and it spins freely. when spinning the tire the front drive shaft spins while turning wheel..
