1 - 17 of 17 Posts
chevy
Any one know how to determine what size sway bar I have in the front or how to measure it? I want to replace the front sway bar bushings. 2002 LTZ 4X4. Called dealer already with VIN, they don't know jack.:hopelessOreily's has a 1.72" bar Moog bushing or a 1.8".
In '02, they really only used one front sway bar, however it was an odd size (42.5mm) and is referred to as 42 or 43mm, depending upon the resource you're looking at. You want a 42mm bushing, it will compress when you tighten up the bolts.....Auto-Zone sells them, in addition to the dealer. (They're actually pretty cheap to buy in the original rubber and Energy Suspension makes a poly bushing also sourced to Hotchkis for their kit).
You measure side to side, if you want to measure your bar without a caliper. Place the ruler on the back side, line up one edge with 0 and read the where the other side at the point you can see looking head on. With a caliper, you crack it or allow the spring load to grab the widest point and read the gage. (Should be 42.5mm for an '02).
chevy
No. A 43mm is closer to 1.69"
Thank you sir. I went and got the bigger bushing and found out that it had a slight gap. Have to return it tomorrow and get the one for the 1.72" bar. Wish I would have read your post first. :suicide:
Anyone know what size sway bar bushings would be on my 2003 Trailblazer LS? Thanks
Reread posts #1 and#2. There are different sizes. You need to measure yours.:thumbsup:
I don't have a mic, and trying to measure the bar with a tape or ruler, and tell the difference between 1.72" and 1.8" is nearly impossible. I found the GM P/N on the bar, it is 15167261. Can anyone tell me what size bar this is? I want to order the Moog bushings and links online, and want to make sure I get the right ones. Thanks:bonk:
get a thin strip of paper and a pencil. Crawl under there and measure the circumference- mark on the paper and measure. divide that number by pi (3.142) and that will give you the size diameter you need.
Diameter=circumference/3.142
and my 10th grade geometry teacher said I would not amount to anything!
Thanks for the info !! I probably learned that at some point, but forgot it long ago !!:thx
And if the difference is still too small to measure accurately with one wrap-around, you can take string and wrap it ten times (not overlapping) to amplify the difference. Then just divide by 31.4 instead of 3.14.
2009 chevy trailblazer_ss_3ss
You can also take an open-ended adjustable wrench, like a Crescent wrench, and open it until it fits around the the bar around where the bushing will be. Slide it off and measure it with your tape measure, ruler, etc. The distance between the wrench paws is the O.D. of your bar,
Sorry to hijack this thread:eek:, but does anyone have the torque values for the bolts that hold the bracket for the sway bar bushings? thanks.
So did you find out that it is the 1.72 " bushing then? I am not going to be able to get under the car again for a couple days but want to order them on line since I am ordering the stabilizer links. Man are those things loose.
I ended up not changing the bushings. I changed the links, without dropping the bar, and left the bushings alone as they appear to be OK. Sorry, I can't be more help.
1 - 17 of 17 Posts
