1 - 11 of 11 Posts
2004 chevy trailblazer_ls_ext
Front end seems to squeek when the suspension is doing its thing. Either bumps or the dip coming out of the driveway. I think its on the right side. Anyone else have this issue.
im sure the same oem ones from 2004
Squeaky front end
Mine was squeaky,it was a lower ball joint.Have a friend bounce each side up and down,you can feel the lower ball joint grinding and squeaking.
Does it do it when you brake? i had a awful squeak noise and it took me forever to find out it was the lower control arm bushings. and if that is the case, it is mad money to fix so i just use this silicone spray stuff every now and then
Also check the brake pads. I had a squeek that no one could find until I took it to a buddy who noticed the ends on the pads were shiny and they were rubbing the caliper. It would stop of course while I was braking going over the bumps.
i had the same problem....it was the rubber bumpers on the corner of the hood...just unscrew them a bit to put more tension on the hood and it should stop.
1 - 11 of 11 Posts
