Hey everyone, I'm hearing clanking noises on the front end, my front differential is leaking fluid from my driver's side axle, and my drive shaft turns freely in park but not in neutral. It's a 2006 TB with a switch that can switch from 2WD to auto to 4WDup and 4WD down. I bought the TB in 2008, but never used the 4WD. About 3mos ago, my 2WD switched to 4WD and locked my drive shaft. After switching the switch back and forth from 2WD to 4WD down, it finally went back to normal. Since then, it makes a rough clanking sound while driving. I've been told that I can remove my front drive shaft. If so, do I need to seal anything afterwards, or just remove the front drive shaft and keep riding
? Any and all help will be appreciated. Thanks
