1 - 3 of 3 Posts
I just changed the gear oil on the front of my 03 trailblazer and there was a nylon washer/gasket on the drain plug. Being that their is a slow leak comming from my differential, I am wondering if the washer is supposed to be there or should it be replaced when changing the gear oil?
It isn't supposed to be replaced when the plug is removed as far as I know. The leak you're seeing is probably from the axle seal.
:undecided Where is it leaking from the diff cover, the fill valve, or the axle seal?
1 - 3 of 3 Posts
