1 - 3 of 3 Posts
I have a 02 Envoy XL (4x4). I had some front end humming noise a while back (vehicle had 120,000 KM at the time) noise got louder when I turned right - changed out the left hub bearing - all OK. At 160,000 KM same noise, this time other side- changed out the right hub bearing. Now I have another humming sound that doesn't appear to change turning left or right - starts at about 30 KM/h and gets louder the faster I go. I am pretty sure that it is not coming from the hubs - as they are relatively new. Vehicle currently has about 168,000 KM. I think the last bearing noise was masking this new noise. I have pulled off the wheel, brake calipers, rotors and spun the front axles. Left side is stiffer than right but I don't hear any grinding. Front axle oil is at the proper level though its quite dark but it doesn't appear to have metal filings in it. I am suspecting its the left front axle bearing. From this forum, it appears that the right side is an easy change - but the left looks like its a real ass pain. Before I get into this, does anyone have any ideas on how to confirm it is indeed this left bearing? and any tips to changing this out.
Thanks in advance
2006 Trailblazer LS 4.2L I6
tpazz, I realize this is a very old post, but did you ever discover the problem? Hearing the same noise on my '06 TBL. Thanks!
1 - 3 of 3 Posts
