So to start off, this is my second time typing this post. I had it all done, and then I hit submit and I had been timed out and logged out, and lost all of my work. So now I am typing it in Word, first. I hope I do as good of a job the second time. I will say it's definitely lighter on words this time, but I think the message still gets through. And now I'm finding out my post is to big, I can't post images, on and on go the error messages....
I had a user name here before, but it was a few years ago and I forgot what it was and had to make a new one.
Back in November, my Dad noticed a growling coming from his 2003 Trailblazer in the front. It sounded a lot like wheel bearings, so he got two new hubs. When I jack up the truck to changed the hubs for him, I found that the frame where the control arm mounts, and essentially completely rusted away on the driver side. I'm kind of surprised there wasn't a bad accident, actually.
So I set about finding another TB, and found one that was also a 2003, the body and interior were shot, but the frame was in great shape and the rear axle was a limited slip diff (Bonus!), so we picked it up, and the project began. None of this would have been possible without the help and support of my Dad (granted, he just wants his TB back) and my best bud Zach.
Ignore the other random junk:
I had originally intended to just do a quick body swap on a friend's 2-post lift, I figured 2 or 3 days worth of work. Well, his shop got busy and I wasn't able to use that. So my Dad and I designed a lift with lumber and chain hoists:
Here's a weight test, the entire donor TB supported with one set of hoists and one 10k pound ratcheting strap... Like a champ!!:
I had intended to use the hoists and straps to do all of the lifting of the body. Unfortunately, there was no good way to lift at the front, and in the rear the strap crushed the quarter panels:
So for the front I was able to hook the hoists directly to the framework of the body, in a slot behind the front fender:
It bore the weight nicely, and allowed for a full lift off of the body:
Then I rolled the frame out of the way, and developed some caddies to carry the body and allow me to safely roll it out side. This is version 2 of the rear, the braces running forward to the second body mount location were added after the first one failed going over a bump. Luckily that was not on the good body, to no harm done.:
In the front, I was able to get away without braces, the steel around the body mount location was wide enough to fully support the 2x6 against flexing. Even so I saw it moving some later, if I did this again I would use braces on the front as well:
Now that I could safely set down and move the body, I wanted to develop a damage-free way to lift the rear of the body. I tried a few things, but decided the easiest way would be to laminate four 2x4's into a beam, and place a 2x6 on top as a spacer, and bolt it to the body mounts inside the wheel-wells. This worked well, and with a few minutes with jack stands and jacks, is not that hard to place or remove when the chassis is underneath. Also, all of these wooden fixtures are bolted into the body mounts to secure them:
The swivel casters on all corners made it very maneuverable, but three people would be the minimum if your area wasn't completely flat- it still weighs a lot!:
Then I moved the good frame out as well, and rolled the black TB in for dis-assembly:
Growing parts pile in yard:
Learning with the other body means it was a snap to make up some more caddies and put them on:
More to come in a moment....
