1 - 20 of 37 Posts
This will end up being a sticky. After getting in a minor accident they had to replace the rear end which meant the sway bar too. The OEM rear sway bar is back on, and I hate it. Previous to the accident I had the Addco brand sway bar bought off ebay, and Moog end links. New sway bar purchase is in full effect. Two sets exist, a new rear bar, bushings, and replacement front bushings, or a 2 bar kit, for front and rear, replacing both bars with all new bushings. Here is what I have found out so far (price high to low):
EIBACH
They sell a kit for new front and rear apparently "tubular" bars. Comes with new bushings all the way around. Here are some stats:
This Anti-Roll-Kit fits the following application:
02-06 CHEVY Trailblazer, 2WD / 4WD - (t) 35mm (F) / (t) 32mm (R)
(Incl EXT)
02-06 GMC Envoy, 2WD / 4WD - (t) 35mm (F) / (t) 32mm (R)
(Incl XL)
(t) This Anti-Roll Bar is Tubular
Only qualified mechanics experienced in the installation and removal of suspension components should
perform this installation.
Free Shipping to Continental United States
I found this on ebay, seller ID is auto-sport-parts
PRICE: US $438.07
Gravana Tuning, a vendor here sells for less:
EIB-3826.320 Eibach 3826.320 Sway Bars - Trailblazer/Envoy/97x Sway Bar Set - Front & Rear
PRICE: US $399.99
Hellwig
I found this suspension item at JCwhitney. Not very much info on it, maybe someone can chime in.
Rear "stabilizer kit" only kit, does not say anything about it actually being an anti-roll bar. Item number ZX494857B
PRICE: US $237.99
HOTCHKIS
The thing about this is the easy-access installation page. It is a how to or DIY for any sway bar installation. http://www.hotchkis.net/files/installation_guides/2272.pdf
This kit comes with a new rear bar, rear bushings, and front bushings. No front bar included. The rear bar is 27 mm thick, and it is hollow. This seems to be a very popular package. There are many prices, here are a few.
PRICE: US $232.99
2004-up Trailblazer, Envoy Sway Bar
1-1/16'' (27mm) Hollow Rear bar This is from Jegs.com item number 515-2272.
Front And Rear Bushings. I know this can be found cheaper, in fact a vendor on this site known as Tbyrne who is currently offering a sale but can always beat the Jegs price price. Also, ebay sells for $229.95, with on average $30.00 in shipping.
BELLTECH
Belltech offers a rear bar that is greater in size than average, 29mm thick. This bar is also offered on this site. I believe this bar is also solid. I found this link via drivewire.com: http://www.drivewire.com/percatalog/Dynamic.aspx?year=2004&PartID=1585N0084&Part=SWAY BAR&pt=4
I believe this can be found cheaper on the trailvoy.com site via a search.
PRICE: US $187.82
ADDCO
The sway bar I originally purchased, The Addco bars are 28mm rear and 31mm front. The rear is solid. It seems any kit that does actually offer a front bar it is hollow, as is the stock one. The ebay solution at this current moment is only a front bar, with bushings(as of 2/10). I believe I paid $130.00 including shipping for my rear bar. If you Message him via ebay he will sell the front and rear bar kit for a discounted price. Ebay ID neverenough2003
here is the link:
http://cgi.ebay.com/ebaymotors/SSR-Envoy-Trailblazer-Addco-Front-Anti-Sway-Bar-2242-SS_W0QQcmdZViewItemQQcategoryZ33592QQihZ021QQitemZ310020768101QQrdZ1QQsspagenameZWDVW
Front Bar PRICE: US $129.00 W/ $20.00 Shipping
Overall it is hard to decide, final price shipped to me will make a big factor. The Belltech and the Addco I had seem like good options, I still would want a front bar if I got the Belltech so I would go with Addco. The Eibach kit is nice because they are the same manufacturer and are designed to go together. I think a solid rear bar is the best choice however. New end links are a must for anyone who replaces sway bars. The factory ones just are not designed for larger/stiffer sway bars.
IMO, I'd go w/ the Hotchkis rear bar w/ the F & R bushings. Haven't seen anything but good reviews of these on this site.
I only use ADDCO on ALL the ones I lower. You can get the front/rear bars for 230 shipped. For the price much better deal than the hotchkis rear swaybar.
Go measure your front bar before ordering any front bar! ..... An '04 could potentially still use one of the over sized 43 or 41 mm bars, which are bigger than any of the replacements currently on the market. All you need are some firmer bushings to totally change the handling of your TB. The factory bushings are soft, REALLY SOFT, I was amazed at the difference between the stock bushing and the poly bushings in my Hotchkis kit when installing them. (Stock was like an inner tube, the poly were like a 60k mile tire in comparison).
So did you ever change out your front sway bar w/a aftermarket one? If so, which one? Is it better to have a bigger sway bar or a smaller one for better handling? Kinda new to this...........
Is having a SOLID sway bar better than a HOLLOW one?
I know for most applications it isn't. If you can get the same stiffness and flexibility from a better designed and higher quality hollow bar, then you're much better off with that due to the fact that it weighs less.
Also, just because a sway bar is smaller, doesn't mean that it will perform worse than what it is meant to replace.
So, if the size of the bar isn't what matters, is there any way to determine the stiffness of the bars? Do the manufacturers publish that data?
I'm using the stock 43mm bar on my '02, but with the replacement poly bushings from the Hotckis kit.......those bushings make a HUGE difference in lean and really firm up the front end.
Generally, a good hollow bar will perform equal to a solid bar of the same thickness. The thicker the bar, the less flex and better control you have in general. - Which is why most of the aftermarket rear bars are thicker than the stock unit. In the back, there isn't a whole lot of room to increase thickness, but some increase is possible. The bushings play a big part of how rigid the suspension will be and most of the aftermarket bars include poly busings as opposed to rubber. (The stock bushings are softer rubber, actually VERY soft rubber, to give a more comfortable ride).
2007 chevy trailblazer_ss_3ss
Does the front bar control only vertical movement? or does it have
lateral movement control/dampening also??
Need help
I'm working in Kuwait and recieve my stuff through the APO. There is a size/weight limitation which is 108 inches (girth+length) and 70 pounds. Can anyone provide the box dimensions for both the front and rear swaybars?
I really appreciate any assistance, Thanks.
I'm using the stock 43mm bar on my '02, but with the replacement poly bushings from the Hotckis kit.......those bushings make a HUGE difference in lean and really firm up the front end.).
The Hotckis web site says the kit fits only '04 and up...which made me think the poly bushings they provide with the kit would not fit my 2002 43mm bar. But it sounds like it fit your 2002 with the large bar? Does your paperwork happen to have a part number for just the bushings? I'd like to try and order just the fornt bushings. Thanks!
I just ordered all new endlinks for the front and rear but I am gonna wait on installing them so I can get the Hotchkis setup so I can do it all at once :yes:
whats exactly is the rear sway bar ? does anybody know if this plays a big part in the raising of the rear suspension? thanx
Discussion Starter #18
It does not, in any way, effect the ride height of the vehicle when not in motion. It reduces roll (side to side movement off of a flat, horizontal line), by connecting the rear axle to the frame with a slightly flexible bar and movable end-links. A heavy duty or sport rear sway-bar will reduce roll in the rear of the vehicle. It will not effect ride height.
Like to hear more on which would be the best combo setup for a 2003 Trailblazer EXT that is stock and what endlinks is everyone using? Has anyone used the MEVOTECH ones?
Can I swap out the stock front sway bar bushings for the poly ones without having to change out the actual bar? I noticed that Hotchkis sells a rebuild kit that contains said bushings and grease packs for them for ~ $60. Doable TrailVoy?
1 - 20 of 37 Posts
