I think my fan clutch is stuck on, and im just wondering if anybody else has had any sort of problem with this. And could give me some suggestions on what you all may think it might be other than that. It sounds like the fan is working extra hard when i hit the gas to take off...i did notice a "clicking" noise that had started last week, but then it would go away after a couple min. so im not sure if that has anything to do with it or not?
2005 chevy trailblazer_ls_ext
A large percentage of us have had to replace our fan clutches. There are a few that have said they still have the original one, but they are the exception, definitely not the rule!
Your symptoms sure sound like a bad fan clutch to me.
It is a fairly easy thing to change, if you have ever worked on a vehicle before. There is a write up on here and several other threads. Click on the "search" box you will have enough reading to keep you busy for quite a while!
