1 - 3 of 3 Posts
So I just changed out my fan clutch yesterday because it needed to be changed and I kept getting the code P0526. So after changing it it did good for maybe a day if that, went to take it to get smogged and failed since I needed to drive it around more. As soon as I leave the lot, my code comes back, is there any way I can fix this? Also could it be a bad water pump? Any help is appreciated
when you replaced the fan clutch, did the replacement come with the harness from the clutch to the radiator shroud?
Do you have a multimeter? Have you checked the 5 volt circuit to the hall sensor for the fan speed?
1 - 3 of 3 Posts
