1 - 8 of 8 Posts
gmc envoy_sle
2002 Trailblazer, bad vibration at idle, removed serpentine belt, most went away, with belt back on,it can be felt in the fan shroud. I was wondering if anyone has had this problem, planning on replacing clutch, and fan, planning on removing clutch assy and see if vibration goes away before I completely disassemble...just unscrew and secure it out of the way.
Bill
gmc envoy_sle
Probably Water pump, unscrewed fan and laid it out of the way, started engine, vibrate not as bad but, still some there, pulled slack in serpentine belt, was able to move pump assy some, gonna replace pump, and clutch. I'll post if that don't fix it.
Thanks for the input...Bill
gmc envoy_sle
Discussion Starter #4
Fan clutch
Replaced fan clutch, and water pump, very little, if any difference.
Just going to drive it til something starts to make noise, then start over.
Bill:duh:
gmc envoy_sle
Discussion Starter #6
99% sure,it's the fan. With the belt off smooth as silk, been swapping clutches, and blades, finally traced it to the blade, put new blade on ...it wobbles and vibrates so bad, can't hardly stand to drive it. Working on it later today, I'll post when I get it going.
Bill
2006 chevy trailblazer_lt_ext
clutch fan
had a vibration from engine---- 4.3 chevy blazer--- removed belt vibration stopped. replaced clutch fan assy. runs smooth. new fan and clutch fixed it for me good luck:)
gmc envoy_sle
Discussion Starter #8
Da FAN....replaced with new fan, worse than ever...Replaced with Upullit fan, much better, it's bearable for now.
Thanks for all the input...Bill
P,S. I've got it down to a 30 minute job now that I know what tools are needed.:woohoo:
1 - 8 of 8 Posts
