My Envoy started acting up. It's a 2004, 56K on the clock. Un modded, grocery getter.
Anyways, the problem is when I let off the throttle, the headlights kind of short out. I say kind of because they don't cut out, but they dim. Driving home this morning (after it has sat over a month) it was flickering all the way home, about 25 miles. If you were driving ahead of me, you'd think I was flashing my brights at you ( going from low lighting to regular ).
When I got to the 'voy, it was completely dead. I jump started it with a Powerstroke and it fired right up. However, when I went to use the power lock to open it, that was a no-go. Same with any kind of interior light when I opened the door. DEAD. Key wouldn't come out of the ignition.
This problem started about 2 months ago, but not as severe, and just chalked it up to being a GM product (see signature), so I'm pretty sure the jump start wasn't the issue. I also noticed the voltage gauge (stock) dopped to around 11v a few times, but otherwise stayed right at 14v (I'm guessing 13.8 is what it runs at?).
It is the oem battery, so that could definitely be part of the problem. I let the truck sit for a month or more every time I use it when I get to town, so could something be jacking it up? Also, when I say it has been doing this for a few months, but much MUCH less severely, and never had a battery issue. I'm guessing it could also be a alternator ready to take it's final ****.
Apologizing in adavance if this is written 'tardedly. Had a long day loading multiple stops of electronics in Toronto, got my semi truck seized and searched for 3 hrs and just got home and haven't slept in a loooong time. Any help or ideas are greatly appreciated.
Thanks Joe. I'll head out and get one today.
And advanc apology for not using the search function. I'm really strapped for hometime. I only come home for a day or 2 every month and a half, and the clock is ticking :eek:
this happened often in my grand prix, and i replaced the battery... and the problem continued. turned out the battery terminals were just that oxidized that it was draining everything. try a good cleaning on the terminals and the cables... might do the trick.
I have the same problem and replaced the battery but it didn't help. From what I read on here, it sounds more like the crappy GM side terminal battery cables. I never did like them! :hissy:
