1 - 9 of 9 Posts
2007 gmc envoy_slt
2007 Envoy AC clutch engages and AC works well but it comes on when you turn on the fan (to any speed). The AC on/off switch lights when pressed but doesn’t do anything. AC blows cold and the compressor cycles as it should. So anytime the fan is on, the compressor is engaged and I can’t turn it on or off with the AC dash switch. Any ideas?
This is only an educated guess, I would have to suspect the control panel itself. If it were the compressor relay, the blower switch would not affect it. You might want to go to a salvage yard and see if you can pick one up there.
2007 gmc envoy_slt
Discussion Starter #7
Solved
I tried disconnecting the battery for a few minutes. It’s now working the way it should! Got to love such an easy fix. Thanks for your help in any event.
That's a new on me. That usually will only cause the system to recalibrate the actuators. Glad it is fixed.
2008 isuzu ascender
Yeah it weird the way that works . I was having all kinds of issues with the stupid TPMS system and as last resort I pulled the fuses to the BCM for 3 minutes and reinserted and never had another issue . I LOVE COMPUTERS !!!
1 - 9 of 9 Posts
