1 - 11 of 11 Posts
We've added the ability to embed Google Maps into your posts:
Click the
button in the editor while typing your post and the maps tags will appear, you can then type the address, coordinates, zip code, whatever you can type into the Google Maps search fields can be entered between the map tags.
This is helpful for pinpointing meets or events or to show a location that you may be referring to in a post.
Here is an example:
The tag above will display:
[map]
Testing Feature
flagpole knob, va
Seems to work fairly well. You have to be specific though. We can't seem to input lat/lon coordinates?
Invalid address: +38° 31' 8.74", -79° 10' 48.04"
If I type that into google maps, it works... but not using the {map} quotes.
Discussion Starter #6
flagpole knob, va
That seems to be a limitation of the feature, I will see if I can find a way to get it to work :undecided
1 - 11 of 11 Posts
