1 - 17 of 17 Posts
'05 Chevy TB EXT
{quote]I put a electric fan on. So is there anything else I need to do? To get my motor to run right.[/quote]
Let me see if I understand you --- your fan motor is running badly after you swapped it into your vehicle?
I see the YEAR --- post the MAKE - MODEL - ENGINE SIZE - ANY CODES YOU SEE - TRIM LEVEL
You will need something to fool the ECM into thinking the electronic fan clutch is still there.
Within the last month there was someone on here who claims they devised what I will call a "black box" that does just that. I suggest you use the search function and search for "electric fan".
Good Luck!
I see you found the posting.
  • Like
Reactions: Ravalli Surfer
My clutch fan was bad. So I replaced it with a electric fan. Now I getting a code say something about the fan relay. I understand I need to fake out my pcm. Just not sure on how to do this.
I'm sure you did, I am hoping the OP sees it.
OP, if I recall the thread correctly, the cost of the mystery "black box" is about the cost of a decent electronic fan clutch that comes with at least a 2 year warranty. I'm not sure what you'll do if the "black box" goes wonky. My solution is to go to rockauto.com and order the Dorman electronic fan clutch as it comes with a lifetime warranty and it is manufactured by a company with a decent history.
  • Like
Reactions: yankee56
'05 Chevy TB EXT
I think this is succinct and if any OP requires more info, it can be posted for them.
DO NOT DISCONNECT THE BATTERY UNLESS SOMEONE HERE TELLS YOU TO.
If you do this foolish thing, you run the risk of damaging already
old and brittle plastic gears inside the HVAC electronic controllers
There will be clarification later if you wish.....​
Oh, you meant that boilerplate message! I'm fighting a migraine this evening so I'm a little behind o_O
I can understand with all that cold and dry weather you are having. Supposed to warm up here this week, so I am hoping to make progress on packing and finishing up making sure all vehicles are road worthy for the trip home.
2002 Chevrolet TrailBlazer LTZ 4.2L
I did the same. Installed a Flex-A-Lite electric fan to replace my failing clutch and get a more reliable cooler without the extra lateral load on the engine. To fool the computer, a company called PCM of NC has a program where they recode a PCM to your application and can remove that code, as well as a wealth of other possibilities to improve performance and fuel economy. Might be worth checking out.
'05 Chevy TB EXT
Just be careful of diddling into the transmission op/sys.
Many "Tooners" like to jack up the output of the pump by having it swing to a higher pressure/output position just to harden the shift and although it might feel good, it puts a lot of strain on what is likely a high-mileage pump - pushing it to run where it isn't happy.
I've seen and heard of a lot of pumps that fracture after getting a recurved ECM.
.... just sayin' .................
Transmission was the one thing I didn't mess with, especially after the pretty stack of pennies I spent getting it rebuilt.
1 - 17 of 17 Posts
