1 - 3 of 3 Posts
well heres my tb
when i bought it i noticed a few things. the owner had a cb installed. and also a system installed. i could tell from the wiring harnesses added in towards the back seats and little slots in the carpet running cables through.
heres the thing though my ebrake never worked and i figure he had a touch screen installed but instead of googling the damn codes or grounding it out another way to play video while driving he connected it to the ebrake like he was supposed to but disconnected the actual break.
how would i go about getting this hooked up again?
Not disputing your conclusion but I'd suggest first try adjusting the ebrake. It's fairly common for them to need adjustment... in fact I've had to do it a couple times within the first 50000 mi. The ebrake had become completely ineffective.
The brake itself is a small drum that is inside the rear disc. The "official" adjustment procedure requires the disc to be removed and the shoes adjusted based on the diameter of the drum however most use trial and error.
Here's a link with good info: http://forums.trailvoy.com/showthread.php?t=53680
2002 olds bravada
:iagree: thats a great thread to read. also, while having the wheel and rotor off, check the condition of the shoes.
1 - 3 of 3 Posts
