1 - 3 of 3 Posts
I looked at the drl module diagram on v-leds.com and i really dont follow it to well. Can anyone give me an idea of where this module goes? I dont have a relay on my HID's they are run off factory harness.
Ok i downloaded jetttstreams diagram and its much better. So if i dont use a relay harness the DRL module would go between my ballast and my light bulb connection correct?
Wow so i go to put this drl module in and now my 1 side is not working at all..High beams/Turn signals work fine but the low beam is not working. Could it fry the bulb or ballast? How can i check. Test Light?
2002 olds bravada
You probably got the negatice postive switched around and blew the module. Try using your HID's without the module and turn the headlight switch on and see if they come on.
1 - 3 of 3 Posts
