1 - 6 of 6 Posts
Anyone have problems opening drivers door when its cold ? Mine wont open unless you pull real hard i mean hard. All the other doors open fine just the drivers door is a real pain:mad:
That could be a sign of alignment problems with the driver's door. I'm sure theres a way to adjust where the door latches. Unless if the door hinges are just old & worn. An easy way to tell if it's the hinges is by opening the door & just try moving it up & down. If it moves it could be your hinges.
Is it sticking against the weatherstripping? Mine will sometimes do that when it is cold. Wipe down the strip with armor all or a thin coat of vegetable oil and see if that fixes it.
Discussion Starter #6
Checked hinges and found door stop pin locked up tried some of loctites freeze and release on it waited about 5 minutes now it works great. Thanks
1 - 6 of 6 Posts
