1 - 3 of 3 Posts
I just purchased a 2002 Trailblazer. I noticed the driver mirror will not adjust and the turn signal on the mirror does not work either. Checked the bulb and I believe all fuses and found nothing. The passenger side is working fine. Any direction would be appreciated.
You're gonna have to start probing the wires that feed that assembly. The usual culprit is the wires themselves where they flex and are inside that corrugated rubber tube that goes between the body and the door under the hinges.
So I popped out the switches on the drivers door to start taking the panel off and trace wires and test them. Come to find out the mirror was unplugged from the underside of the switches. So I guess on to the next project.
1 - 3 of 3 Posts
