Driver side door makes a sharp, cracking sound when opening/closing; passenger door is fine - - so far! Followed the suggestion to remove the rubber cover plate near the hinge and spray some white lithium grease in there, but that didn't help at all. Would appreciate any other suggestions out there short of taking it in for replacement.
Steve M.
2002 TrlBlzr 57K
Re. Door "Strap" Noise
Door, nor fender are not out of alighnment. I suspect it's either a lubrication problem, or a fitting (hinge) behind the door panel and inside the door that has worn out?
With the window up, spray the hinge with a penetrating oil. White lithium grease is good but it doesn't spread as well as something like WD-40.:m2:
