1 - 3 of 3 Posts
I am wanting to remove the plastic trim pieces from my doors and was wondering if anyone has had paint come off with the adheasive when they are removed?
Are you tallking about the exterior trim molding on the the door? If so....then no......all you need to get the work done is heat the moldings up with a heat gun and pull away...I know it sounds easy but all you need is time...what you need to get the moldings off:
Heat Gun
Dental Floss
Goof off or goo gone(adhesive remover)
wax
Remember to do this on a nice day as this will take about 3hrs or so.....Good luck
1 - 3 of 3 Posts
