1 - 8 of 8 Posts
Short answer: Yes. If it is the stock 8" rear differential, and the 4.10 gear set is 8".
You can put the 8.6" EXT differential in and it is recommended because it is stronger than the 8" ring gear made for the SWB trailblazers. It will bolt right in and roadie has an entire thread on his conversion. Also 4.10 gears are rare so jump on it!
does a GT5 differential fit in a regular 03 trailblazer ls
Are you talking about swapping the gears you have now and putting a 4.10 (GT5) gear set in? Or replacing the entire rear diff that you have, with a different diff that has the 4.10 gears? :confused:
Discussion Starter #5
was thinking of replacing the whole thing, if i could find it. and if its possible
Discussion Starter #6
so the ext diff will fit perfect??
as long as its the same gear ratio so it dont screw things up, Yes
certaian newer years have speed sensors at each rear wheel in the axle. I you dont have them, any year will fit. If you do then you need one of them.
Hey guys sorry if this question has already been asked but I have a 2005 TBZ LS and I’ve been thinking about doing a differential rear and front swap. I have a gu6-3.42 can I change it to a 4.10 directly? Do I have to do more then just swap out?
1 - 8 of 8 Posts
