1 - 12 of 12 Posts
I am thinking of removing the molding and debadging the vehicle, but before I make that commitment. How is it fastened to the vehicle, badges and side moldings? and if I do remove them what should I expect to see beneath the covered area? also What is a good easy process to accomplish this? Any help would be greatly Appreciated!!!! :hail:
Discussion Starter #7
I figured as much but I didnt want try something and mess up. If you find the link post it I would love to check it out. Im looking too. there are some pretty awesome looking TB's out there. Im just starting my build out now...:woohoo:
2003 trailblazer_lt
I couldnt find a be-all end-all thread
Everything is held on by double sided tape...some people have used a heat gun or hair dryer to loosen up the glue, but I let mine bake in the sun for a few hours, used fishing line in between the badges/body, and then used a rubber eraser to get the residual adhesive off (some people have used goo gone)...finally I used mequires 3 step (cleaner wax, polish, wax) to make it shiny.
2006 chevy trailblazer_ss_ls
Use fishing line to remove the molding/letters. Some people say to use goo-gone to remove the "sticky stuff", but I swear by Turtle wax bug and tar remover.:thumbsup:
I see you're from Ohio. If you haven't seen it yet, there's a big meet in C'bus in the spring. Check out the link in my signature line.
Discussion Starter #10
My 05TB Molding Removal
Here is what I did with everyones guidence. The Fishing line got me started but was getting painful even through leather cloves and hairdryer. So I caled a local body shop and got some help there and boy did that go faster...
Step 1
Get a 7 in 1 tool and a Heavy non abrasive towel.
Step 2
Wrap the Towel Doubled up around the Blade end of the scraper
Step 3
Plunge the covered scraper end into the space between the body and molding and draw the towel into the space pulling with the towel very slightly to seperate and Clue and molding.
Step 4
Remove the towel and pull using good old hands to seperate the Moldings. PULL SLOWLY
Step 5
Inspect the Area and Repeat with the other Moldings. Keeping in Mind that your only using the scraper to push the towel in the space and not the scraper to remove the molding. I was informed by the body shop that if you push to hard from the scraper you can go right thru the towel and into the paint, so you have been warned.
Keep in mind the fishing line works just fine and is quick too. I tried both and found the body shops way faster but more dangerous. Just my opinion, like always handel with care and good luck on all projects remember move slowly and heat the area thuroughly or warm it in the sun.
Be careful on how quickly you pull on that stuff, I debaged my SS and had a few spots where the paint came off with the glue. Not fun. :hissy:
1 - 12 of 12 Posts
