OK, so last night I decided to swap all my filament cluster lights to LED. Went pretty smoothly, took the board out to the truck for a successful test before putting it back together. Went to reinstall the cluster, and while showing off to one of my neighbors, noticed that all of the cluster lights remained on while the truck was off, and key out of the ignition. :ugh:
Remove the cluster and recheck everything, one of the resistors had gotten pushed a bit, causing one of the leads to touch the board where some traces were. Small adjustment, and all was right with the world (or so I thought) Put the cluster back in, stepper motors gave a quick buzz, and the lights worked properly. BUT, now the odometer and gear selector was out. :duh:
In the number of threads I've read this morning, I've checked fuse #24 up front, all of the TBC fuses (front and rear) with a fuse tester (handy lil device I didn't know I had) and confirmed proper voltage on the orange and pink wires in the cluster harness. I did see some suggestions of bad grounds, but I'm pretty sure if I shorted something, that wasn't gonna be the issue.
Are there any other things I can check/fix on my own, or am I screwed and gonna have to send this out to get fixed (or worse buy another cluster) :sadcry:
