· Premium Member
Just want to give you guys an fyi, I replaced the idler pulley today just to see if that fixes my squeel which has returned and the one made by Dayco and sold thru Carquest does not fit. The washer doesnt seat properly. I ended up going with a Goodyear and fit perfectly.
one of the aftermarket idler pulleys- can be used without the washer.
Im pretty sure its the Dayco one.
Sounds weird to put it on without the washer- but the bearing is sealed and does not need the washer
· Premium Member
Yep thats the same part number 38006 thru Carquest. I just wasnt sure if without the washer the pulley would be off and would burn out the bearings or ruin the belt. Thanks for the info.
