1 - 8 of 8 Posts
Okay, the Xpresskit XK01 supports a metric buttload of features through the D2D interface. Has anyone here actually installed the XK01 using the D2D interface?
I'm going to be installing a Viper 5901 and the XK01 in the next couple of weeks. The D2D connection will reduce my install to 11 or 12 wires total, including the remote start harness.
The main reason I want to use D2D is because of the additional remote start inputs and accessory outputs. The XK01 is supposed to supply tach and brake status, and activate rear defroster/heated mirrors through the OBD II connection.
Does anyone here have any experience using the D2D connections, and will it supply the inputs and accessory outputs on the Trailblazer? If you have installed using the D2D, what features are supported and what isn't?
I used the D2D link with the XK01 module and Viper's 5301 remote start; this past weekend on my truck. The only additional wires that you will need to install on the XK01 module when using the D2D Link are the Data Bus Link input wire and the dome light supervision (+/-) input wire. The rest of the wiring is made with the Viper remote start harnesses. Here's what I connected to make the system work. (Remember to program the XK01 module and the Viper Module before attempting to start. My Viper System required me to change the transmission mode from manual (factory setting) to automatic. Also, remember to preform the Tach Learning.)
H1-1 RED/WHITE Trunk release output XK01
H1-2 RED 12v constant RED IGN HARNESS
H1-3 BROWN Horn output BLK/YLW IGN HARNESS
H1-4 WHITE/BR Light flash isolation wire N/A
H1-5 BLACK Chassis ground GROUND CHASSIS
H1-6 VIOLET Door trigger input XK01
H1-7 BLUE Factory horn input N/A
H1-8 GREEN Door trigger input N/A
H1-9 BLK/WHT Dome light output XK01
H1-10 WHITE/BLUE Turbo timer input N/A
H1-11 WHITE Parking light output BLK/GRAY @ SWITCH (-)
H1-12 ORANGE Ground when armed output N/A
H2-1 LT GRN/BLACK Factory alarm disarm output XK01
H2-2 LT GRN/WHITE Factory alarm arm output XK01
H2-3 WHITE/VIOLET Aux 1 N/A
H2-4 VIOLET/BLACK Aux 2 N/A
H2-5 WHITE/BLACK Aux 3 N/A
H2-6 LT BLUE 2nd unlock output N/A
H2-7 GRAY/BLACK Diesel start input N/A
H3-1 PINK Ignition 1 input/output [email protected] HARNESS
H3-2 RED/WHITE Ignition 2 input RED/[email protected] HARNESS
H3-3 ORANGE Accessory output ORANGE/BROWN
IGN HARNESS
H3-4 VIOLET Starter output [email protected] HARNESS
H3-5 RED Ignition 1 [email protected] HARNESS
H3-6 PINK/WHITE Ignition 2 output [email protected] HARNESS
H3-7 PINK/BLACK Flew Relay input N/A
H3-8 RED/BLACK Fused accessory/starter input N/A
1 BLACK/WHITE Neutral safety switch GROUND @ CHASSIS
2 VIOLET/WHITE Tachometer WHITE @ CLUSTER
3 BROWN Break shutdown input WHITE @ PRK SWITCH
4 GRAY Hood pin switch VIPER SWITCH
5 BLUE/WHITE 2nd rear defogger N/A
1 BLUE Lock/unlock output XK01
2 EMPTY Not used N/A
3 GREEN Lock/unlock output XK01
Hope this helps!!
2006 chevy trailblazer_lt_ext
Hi thanks for posting, made my install go quickly. Few issues im having thou...
I cant seem to get the rear hatch glass to pop open and also if I leave my heat or A/C on shouldn't it come on when I remote start the truck? Just wondering if yours worked with the above set-up or is there something else I need to do or did I miss something.. haha.. any help appreciated.
Cheers..
H3-3 ORANGE Accessory output ORANGE/BROWN IGN HARNESS
The problem may be that on my 2006 TB there is no Orange/Brown.. There is a Orange and a Brown. Neither one of these seem to work by themselves.
I see on the TB wire diagram that They both need to be used for Remote start.. can anyone clear this up for me?
ok.. H3 - 8 Red / Black needs to be hooked up to 12v, that powers the accessorys.. like the HVAC.
I still have a issue with check engine light coming on with remote start thou... I am also only using the orange wire as people state brown is not needed from ignition.
anyone....
2005 buick rainier
IGN HARNESS
Hope this helps!!
Hey Green Monster, would you (or anyone else for that matter) have a manual that shows where each of these wires are? I'm thinking of installing a Viper 5901 (or 5902 when it comes out) in my '05 Rainier (I6/2WD) but need to know where to find these wires.
Thanks!
1 - 8 of 8 Posts
