is it abs pipe
How is it holding up? Dont exactly want plumbing in there but it is just the intake i guess
One of the best DIY I've seen! I like it👍🏿Finished modify my air intake thanks to the help of other member posts on this site. The MAF sensor really hinders extreme modifications to the stock system. My goal was just to keep it clean with minimal intrusiveness. Also wanted to be able to put back the stock air flow if needed. So no cuts to the stock setup. A K&N air filter is in the airbox. Looks good. Sounds even better. Pics below.
The next step is to fabricate a "cold air" duct that will pipe into the airbox for a ram air effect. Still studying my options on that one.
One of the best DIY I've seen! I like it👍🏿 What size is that tube & how did you get the K&N stuff on there? Really nice bro💯👍🏿Finished modify my air intake thanks to the help of other member posts on this site. The MAF sensor really hinders extreme modifications to the stock system. My goal was just to keep it clean with minimal intrusiveness. Also wanted to be able to put back the stock air flow if needed. So no cuts to the stock setup. A K&N air filter is in the airbox. Looks good. Sounds even better. Pics below.
Ok, I got it! You painted the pipe black & stuck the K&N sticker on it! You had me scratching my head because you did such a good job, it looks like it's a K&N vinyl wrap! I have a 2005 and so I don't have that MAF or MAP whatever it is (brain fart) I have the airflow temperature sensor I think it's called 🤔. But I think I will hold on to the stock hose coming from the air filter box for a while until I snatch all of that Secondary air injection pump crap off & get my PCM Tuners tune! I've gotta idea about keeping my intake resonator but with a few mods that involves "Plastic Welding", but I have to find a place that does that because me & my Dremel & a hot butter knife ain't gonna get it...LMAO. You gave me so e really good ideas!nI know this is an old thread but a good idea is a good idea & thanks💯👍🏿Finished modify my air intake thanks to the help of other member posts on this site. The MAF sensor really hinders extreme modifications to the stock system. My goal was just to keep it clean with minimal intrusiveness. Also wanted to be able to put back the stock air flow if needed. So no cuts to the stock setup. A K&N air filter is in the airbox. Looks good. Sounds even better. Pics below.
